How to remove rear yoke from tCase
BigTirez
I have an 84 Ranger with, I will assume the BW1350, Tcase. My U-joint on the rear shaft at the Tcase failed and busted yesterday. I didn't notice the vibration cause I was pulling a POS trailer, so long story short....Before the U-joint failed it tore up the strap mounts on the yoke and is not safe to use. Is there a way to get that yoke out without removing the Tcase and tearing it apart?
Please help!!!
Should be a 30mm nut in the center of the yoke. Just remove the nut and the yoke pulls right off.
It'll actually be easier to do with the case in the vehicle than out if you don't have an impact gun (stick it in gear to keep the yoke from turning while you loosen it).
