How to remove fuel injectors?
matt12305
Washington
It's time I get the fuel injectors on my 2.9l V6 cleaned..how do I remove to fuel injectors to get them cleaned..do I need to remove the intake manifold?
Thanks in advance
Yes, you need to remove the upper intake then remove the Fuel Rail, it is sandwiched between upper and lower intake, top of injectors are connected to fuel rail, but its just a pressure fit using o-rings so they may or may not come out when you lift fuel rail up
Injectors are connected to lower intake with o-rings as well so just pull out
Lower intake does not need to be removed............unless you drop something down the open holes, lol, so be careful, put rags in the open holes
