1990 stx 4x4
- May 22, 2014
- Automatic
Hi new to the site, but best ranger site I have found. I have a 1990 Ranger STX extended cab 4x4 with a 4.0 engine and auto trans. 35x12.50x 15 BFG
Started out replacing ball joint but after reading your tech section I am rebuilding complete front end with all suggested upgrades including 1996 duel piston calipers.
My question is I pulled all the bolts out holding the carrier in place, but there is a pinch bolt in the way of removing the carrier. Do I have to remove the leftside Radius arm to pull the pinch up and out of the way, or can I grind the top of the Radius arm just enough to pull the pinch bolt out ??
Do I have to reinstall the pinch bolt...10 bolts hold the carrier to the axle housingand I dont see the use for the pinch bolt.
any help would be great.
