logman7777
This horse has been beaten enough already
Sent from my SAMSUNG-SGH-I547 using Tapatalk
Crowding out the 4.0 section are we?
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
I think maybe you have a misconception on the Cold Air Intake(CAI).
Warmer air is less dense than colder air, i.e. "hot air rises", hot air balloons, ect.
The point of a CAI is to keep the air going into the engine as cool as possible so the "air temp" sensor on a fuel injected engine will see there is denser air and add MORE fuel, so better performance, but less MPG.
This is why engines are peppier in colder months, colder air = more fuel added = more power.
So generally you will get better MPG in the summer than in the winter.
And CAIs are a bit of a scam, if you want to have cooler air in the intake put in a 160deg or 180deg Thermostat, it will do a better job than a CAI, but won't sound as good.
Best way to get better MPG is to cut down the weight, run narrower tires, leave tail gate UP.
And make sure engine is in good tune, run 192-195deg t-stat, make sure air "pre-heater" is working
New O2 sensors wouldn't hurt, 60-80,000 miles is the recommended expire for these.
Rangers have poor aerodynamics, but cars with good aerodynamics can't haul stuff, lol, so that's your chosen trade-off
