- Nov 7, 2013
I'm new so bare with me. and i thank you all for you imput and info. I'm going to be buying a '96 ranger with a 2.3 sohc waste spark ign. 4x2 5 speed man. I've owned rangers in the past and have better luck with mileage out of a full size truck . The other rangers I've owned got about the same milage as my v8 full size maybe a little better but nothing to write home about. I'm a die hard Ford guy but currently driving a (it hurts to say) 1991 dodge shadow america 2.2l 5 speed man. Although the odometer does not work im guessing I'm averaging about 30-35 mpg and it's going to hurt dropping in mileage. I'm thinking with a shit ton of work and thought, I can better the mpg on the ranger with the old school methods like making a cold air intake (I'm a broke mofo so I build what I can and buy cheap) I'm thinking of using 3" exhaust pipe and wrapping it in header wrap to deflect the heat for the cold air intake and making the exhaust itself as free flowing as possible. Also was thinking on gasket matching upper and lower intakes and changing to hotter plug. Just wondering if it would be worth the effort and how would I tune it to my mods (should I advance the timing a degree or 5 )and was thinking on changing the final drive gear to a high ratio but would need to find a speedometer gear any thoughts?
