97 Ranger, finally tired of not being able to use heat/ac correctly due to blend door issue. I ordered the dorman kit where you cut an opening in the bottom of the plenum to extract the old blend door and install the new part. I have the access hole cut in the plenum, but my original blend door still has probably half the "axle" seated in the hole in the top of the plenum. Does anyone have any tricks for (breaking?) removing the old blend door without breaking anything else?
So many threads and videos on blend door issues, but I haven't been able to find one that addresses this.
Thanks
Keith
Thanks
Keith
