How to determine original & current ride height (whether stock or lifted)
ZeroHour
Fort Worth, TX
2.9 V6
I've done research over the years a bit here and there but never nailed it down. I know for example, there was the high ryder in the 80s but from what I read that was a single cab? I know STX models may have a lift? Somewhere along the lines it gets jumbled up for me though.
Anyway, I feel I may need to replace my springs up front and I'm trying to correct the ride height (hasn't been quite right since that crazy moment involving mud, clay, and an uphill yank involving an f250 that couldn't hear the horn implying stop over it's own diesel..) HOW do I determine if I've a lift, if it's stock for it's year, or what? Looking to replace springs and get correct shocks.
I plan to order a Marti report just to see what was extra when purchased but that'll be later on.
I don't think the STX Highrider appeared until 1987 (I see '86 for your model year). The easy way to tell though (if it's factory) is the presence of RIVETED-in drop brackets on your radius arm frame crossmember (bolted-in ones would not be stock, and could be an aftermarket lift).
If you do not have drop brackets or spacers of any sort lowering the crossmember, then you should be able to order coil springs simply based on your model year, engine & body type.
There's still the chance your truck could have a leveling-coil lift on it, which is harder to tell without another (stock) truck next to yours to reference it to. Typically such springs will sit taller than 11.5" with the trucks weight on them (usually around 12"), but if things are a bit tweaked up under there, there may not be a good way to tell for sure.
I really appreciate it. I'll double check it this weekend and get ready to order a bunch of parts next week so I can hopefully do everything at once, get an alignment, put on my new tires, and call the front end done
Have a look here: https://www.therangerstation.com/stock-ranger-specifications/ford-ranger-dimensions/
Look at Overall Height, in.
1983 to 1992 looks to be 64 inches, and thats the top of the cab in the center, highest point of vehicle
4x4 may be 3 to 4 inches higher, but half of that is larger diameter tire sizes on 4x4s
If you look at drivers door label it will have Stock tire size, so you can check if you have that size now or lager diameter so higher Cab height
Well when I bought it, she had 235 75 15 and that's what I've kept on there since the speedometer reads correctly. Reason I want to replace springs is I've a feeling my driver side sitting lower is because of the spring, and I just want to refresh everything really anyway.
