45acp
I just switched from a 94 extended cab 2 dr. to a 99 ext cab 4 door ranger. I really hate the interior light to come on when I open the door ( I tend to sit with the door open a lot) but I still want the light to be functional when I need it. On my old 94, I did the standard fix that I guess I have done on every vehicle i've ever owned - I removed the switch, capped the wires & plugged the hole in the door frame.
BUT.... I couldn't even FIND the switch on the new(er) truck. Thanks to this fine forum, I read in another post that the switch is in the latch (man thats typical for Ford). Anyone out there have a relatively easy fix for this problem that doesn't require surgery on the wiring harness at the door hinge?
Thanks!
Thanks!
