how to bypass stock amp
rlury
two questions here:icon_confused:
1: Where is the stock amp located in a '95 ford ranger ex cab.
i have read that is behind the "gray panel in the back" what panel exactly is this? the one under the rear window. or the side panel under the side rear window and which side would it be if under a side window.
2: can you hard wire from the harness from the rear of a aftermarker stereo into the speaker and copletely cut out the amp?
