scotiascrapiron
will 2.9 mounts hold a 393
"See me - Feel me - Touch me - Heal me!" -- from the rock opera "Tommy".i made my mounts from stock mount brackets and a block of aluminum.. works great, but they are solid.
Don't use the 4-cyl. engine mounts to install a 5.0L - not strong enough. 4-cyl. mounts are hydraullic, as I understand, and are insufficient for the 5.0L's load.
The 4.0L V6 mounts on the other hand, work fine, with homemade adapter plates. This is what I've done.
But, if I was going to do it again, I'd probably use the mid-to-late 80's Convertible Mustang mounts, switched side-for-side. This requires drilling and slotting the crossmember for the mounts. Several people have done this and posted pics of the installation here, and on RPS. Do a search on "vert mounts".
I'll bet you hear and feel everything the engine does, whether you're sitting in the cab or on the tailgate.
OK! You're cool!have you looked at my avitar?! i see, feel, touch EVERYTHING!![]()
