I have a 2001 ranger single cab, 4cyl, 5spd. If i wanted to put an 8.8 out of an explorer in the rear would i have to change the shock mounts as well as the spring perches.
Maybe he just wants a wider axle or maybe he just has one laying around, or maybe it is easier to find an 8.8 with a lsd in it why can't people just help others out instead of saying hit the search button or that is over kill. next thing that is gonna be said is why take up space on the site with subjects that have been discussed a million times how bout why take up space on the site with threads that say use the search button or that is to big.
If you want to put the 8.8 from an explorer in your truck you will need to flip the spring perches, and since the shock mounts on an explorer are actually on the ubolt plate yes you will have to weld on new shock mounts but no need to buy shock mounts just cut the mounts off the ubolt plate and use them they are actually pretty sturdy. as far as perches go some say if you are carefull you can get the old ones off, but I have tried on 2 different axles and luckily I have already had new perches everytime cause I wasn't lucky enough to get my stock ones off I ended up buying these they give a little lift over the stock ones and they are made out of 1/4 plate and laser cut they are long to prevent axle wrap but with not knowing the application you intend on using this axle for I doubt you will have any wrap. http://cgi.ebay.com/ebaymotors/Dana...ryZ33728QQihZ007QQitemZ170221179192QQtcZphoto
For
