How many vehicles make up your Truck?
lepp1892
Almont, MI
I was thinking about this and I realized that my truck really doesn't have much from the original from ford build.
Rear axle- 90-94 Explorer
Leaf springs- 88 Ranger
Drive Shaft- 99 Ranger
Transfer Case- Not sure but not original
Transmission- 95 Ranger
Engine- 94 Explorer
Doors- 88 Ranger
Bed- 87 Ranger
Front Axle Pig- 93ish Ranger
And It will soon have a engine, trans and t-case from and 87 F150
So I was just wondering how many other peoples trucks are this far from original and how many vehivles they came from.
There are 8 different ones making up my truck right now. Well right before It had the drivetrain pulled.
1985 truck
Takes a '86+ internally regulated alternator
Duraspark box of off 1980's I6 F-150
Ignition pigtail off of a 1980 F-350 400
Distributor for a 1978 Mustang II (same as Pinto but sounds much better)
1986 XL A4LD transmixer, tail light, window cranks and seat
Soon to be...
1987 Mercury 302, carb with 1970's Duraspark ignition (plug and play with my current Duraspark setup)
C4/5 Mutant. RBV's had the C5 in 83-84, dunno what year the C4 parts are
1996 Explorer 8.8 and springs.
1994 truck
1996 explorer leaf springs (coupled with 94 ranger leaves)
2006 M5OD-R1 HD transmission
1998 ranger single piece rear driveshaft
1986-ish 'style' F-250 shock towers
thats all I can think of off the top of my head....
Haha...here goes:
1986 Ranger cab/frame
1985 Bronco II doors/front clip/seats
1984 Bronco II steering wheel
1988 Ranger Dash
1976 F150 tranny/tcase/rear driveline
1976 Bronco front axle
1989 F350 shock towers
1989 Crown Vic 5.0 engine/ '76 Bronco exhaust manifolds
1985 F150 trans bellhousing
1982 Bronco flywheel/clutch/front driveline
1975 Toyota Land Cruiser slave cylinder
1997 Explorer 8.8 rear axle
Think that's about all... my Bronco II only has pieces of three vehicles.
Never added any other year truck part...so far. I bought it new in July of 99. I never thought of adding another year Ranger truck part to it. Maybe one day??? Hmmmmm...maybe I will add larger rotors next year. I just put brand new ones on this summer. I did not think about upgrading to the larger ones until after I put them on....DARN!!!!!
2000 Ford Ranger (mine)
07 Mirrors
03 Level II Rear axle
06 tails
99-00 Expo leaves (each of them are from 2 different Expos!!)
96 OHC
96 door handle
00 4x4 front fender
i think thats all of them
My transfer case alone is made from 3 different trucks.
90 b2
88 b2 doors
89 b2 front clip
94 ranger 4.0
84 b2 rear hatch with opening window.
Bout to have my d35 out of my other 90 b2, with extended radius arms.
cab 87
drivetrain 92
engine ? was replaced before I got it
hood ?
fenders ?
doors ?
rear window?
seats from 93 mustang
bed ?
rims 97 explorer
steering rod lower ?
all I can think of :beer:
At least I'm not the only one that has a mutt truck...
Frame/cab/bed 1998 4 cylinder ranger
Engine: 1998 Explorer V-8
Transmission: A DIFFERENT 1998 Explorer 2wd 4R70W
Intake Manifolds: 1996 Explorer V-8
Slip-Yolk: 1996 Ford Crown Victoria
Rear-End: 2003 Ranger FX4 Level 2 4.10 Posi.
'87 BII body/factory doors chopped to half doors
'91 Ranger full doors
'94 Explorer 4.0 (have, going in soon...)
'93 Explorer D35
'91 Explorer 8.8
'96 Explorer M5OD w/'94 pedal assy, and clutch assy.
'92 Explorer leaves
'87 Ranger steering box
Different '87 Ranger tilt column
'93 Ranger 1354 manual t-case
...I think that's all.
1988 ranger, had an accident years ago,
new engine
87 front bumper
84 passenger door
86 hood
88 driverside fender
89 rear sliding window
plus many pieces of other cars
ok now how many things are not off a RBV?
86 b2 frame
87 ranger engine
89 toyota supra seats
97 explorer m50d tranny
89 RBV transfer case
94 explorer 8.8
94 explorer driveshaft parts
wheels and tires off a jeep
jeep coil's going on this weekend.
88-99 chevy 64in main leafs
94 explorer second, third, and fourth leafs
86 b2 fifth, sixth, and seventh
f 150 front and rear leaf pivot brackets
i'm sure there is more, who remember's tho
