AllanD,
Please correct me if I'm wrong, it has been a few years since I had an M5OD apart.
What about replacing the sheetmetal trough that feeds the oil slinger with a tube from the pump, and removing the delicate oil slinger completely? This would hopefully feed a decent supply of oil to the needle bearings between the input and output shafts. That bearing has my vote as the most critical one in the transmission.
I know from painful experience that if you crack one of the oil slingers when putting the transmission together, that you will get 453.7 miles on an 88 F150 before the input and output shafts weld themselves together. Makes it very hard (impossible) to get apart afterwards too.
Robert
That little "slinger" is actually a pump designed to draw oil
from the front retainer and drive it through the pocket bearing.
That little slinger is necissary, because otherwise oil would need to flow
against centrifugal force to get into the pocket bearing.
Depending on something unlikely for survival is engineering suicide,
so ford used that little plastic turbine, I used to try real hard to get them
off intact and if there was the least doubt to break it in half and drop it in
the trash before using a new one.
That little plastic slinger is argueably the most important part of the transmissions
lubrication system
I could do what you suggest but in the front even a low pressure
pump is likely to overpower the input shaft seal, I'm not wild about the idea of not
only blowing my oil supply out of the trans but blowing it all over the clutch disc.
the next issue is should the pump stop working, for whatever reason,
the life of the transmission would be short afterwards.... IF you completely defeat
the "splash oil" flow path.
at the back of the trans the little spouted cup that feeds oil
into the tailshaft for the 5th and Rev "float" bearings also
needs clean oil but that is easier to route an oil feed line to
What I'd think about using is a low pressure rotary vane pump,
like a Holley Fuel pump. the real point is tapping oil out, filtering it,
cooling and putting it where it needs to go. the rest of the transmission
can take care of itself.
So I have no intention of blocking off the splash oil,
just supplementing it
