How high can i go?
RangerGanja
I have an 08 ranger with a 2.3l 4 cyl. Whats the biggest lift and tire size i can get without breaking my motor?
The biggest you can go would be a 6" from RCD, and a 3" body lift, should fit 35s. Since you have a 2.3, I'd not suggest much more then 2-3" and 32s, even then after a gear swap you'll never be happy with your performance or fuel economy.
u can go as big as u want but like said above new gears will be a must and like said it will never be the same as what you have now. if you do go as high as possible just remeber go slow and take your time wherever you go here is a chart that can help you and it is for a guesstamet its not exact http://www.4lo.com/calc/geartable.htm hope this helps some
