How Far Can I GO
12"-15" or so.
The Superlift, rancho and tuff country arms are the shortest at about 12". Skyjacker, Duff, Camburg, etc all replace the trans x-member so they will be in the 15" range.
Superlift's arms are about 14" over stock. Rancho is 12", SJ is 15".
alright thanks guys its going to be a trial and error deal but i wont be using expensive dom tubing for mock up
This doesn't have to be trial and error by any means. So mant different people have already done this and have documented it that a bit of searching will yield everything you've gotten from this thread and much, much more.
If you're planning on tuckin them up into the frame, what are you going to do to overcome the caster problem you'll likely have? Rememeber, the stongest arm is going to be nearly linear...
yeah idk what im going to do yet i need a set of stock arms to start playing with.
If i use square tubing what size would you guys recommend?
