kenwheeler
I've had this truck for 3 months, driven it 3 times and this is the fourth time I've had to drop the tranny. 1st was to replace the clutch, 2nd was to replace the tranny, 3rd was to replace the slave cylinder (yea, could've saved the third time by replacing it on the 1st or 2nd operation) and the fourth is trying to understand this hydraulic clutch. I just can't seem to get any pedal. I tried replacing the master. Removed the master and tried bench bleeding it again. Everytime I reassemble it I lose the pedal. My next plan is to bench bleed the entire system as a unit, master/slave and reinstall everything while its still connected to the tranny. I need some help understanding how the slave cylinder functions.
My guess is that a new release bearing from the parts store or installed on the tranny but outside the vehicle would look like picture A. When you install the trans and bolt it to the engine the release bearing compresses during the install and looks like picture B. When you press on the clutch pedal it extends against the pressure plate fingers and would look like picture A.
Just to try and see what was going on in there, I hooked everything up outside the truck. After I bench bled the system I used a screwdriver to compress the master. It popped the bearing off the plastic holder that the spring wraps around and gushed fluid. I snapped it back on.
Any help with this would be greatly appreciated. I really want to drive my truck.
