How do you build a compressor with storage tank
94 lngbd
Lakewood,Wa
I have an older yet never used ARB airlocker compressor & a 1.5 gallon air tank that i would like to combine into a unit to mount under bed of truck. Im not 100% sure of what all items are needed plus The ARB has what looks like four locations to install fittings. Two of the locations have allen head caps & one has a red plug,the 4th is under the allen head cap to the right of the picture
Thanks,for any input
Haven't looked at one of these before but from what I see the Red cap at the front would be where you would install an air filter, that is the "intake".
The upper cylinder is the tank, on the side of it, toward the right of the picture, is an open fitting, my guess would be that is the high pressure output.
The other allen key fittings probably give access to lubrication or pressure switches, there should be a pressure cut off somewhere.
Go to the ARB website and see if they have a downloadable manual.
I know that the red plug is not for a filter/intake because there is a brass,screened filter that cant be seen in the pic. I will check with ARB.
Thanks alot guys
I Found out that the North American ARB shop is only 28 miles from me. I contacted a tech specialist there & to my surprise he gave me a entire wiring harnass with ARB compressor toggle switch & a 130on/150off pressure switch for $00. Cant ever say anything bad about ARB
