roughranger
- Oct 25, 2007
ok i have a mud truck iam building with the 2.8 in it. the bronco set for probably a year with \out running. i started it up last night and had all kinds of rust in the radiator. i pulled the radiator hoses off and stuck a water hose down the top hose a rinsed the motor out till the water was clear then put the bottom hose back on and pulled the cap and ran water through the motor and radiator again till it was clear then pulled the radiator drain and ran more water through. my question is can i use like dish liquid in the radiator then start the trruck up and let the soap scrub the inside then drain it and wash it out again? will this do the job and not hurt the motor? thanks rough
