bmob
What happens if your Front Diff is running 4.61 ratio and the back is 3.73?? is that even possible or would the front be spinning faster then the rear? If anyone can shed light on the subject I would be grateful!
a 4.61??? are you sure about that?
4.61 may be a valid ratio if he scored an old old solid axle. They used all kinds of crazy ratios back in the 50s and 60s.
it go kaboom
^this
the gears cant be any more than .05 of a difference, unless you are in a mud drag truck where sometimes they have the front tires spinning faster than the rear (for example maybe 5.13s on the front and 5.32s on the back) purposly. youll tear everything to shreds lol
What if you did different sized tires to make up for the difference in gear ratios? Like you had a smaller tire up front with 4.10 gears, and a bigger tire in the back with 3.73?
