swamprat
- Aug 12, 2007
- lexington KY
- 4.0 V6
bought the truck cheap cause the guy said flex plate was cracked. Pulled trans out today and pulled off flex plate and found this. I am converting to 5 sp. In the pic it looks like a chunk is gone on the left side but it is just scarred up. Do you think the flywheel will set level? The surface of the flywheel that mates to this surface is only as large as the outer diameter of the bolt circle. I could take a stone to get rid of high spots.
What is the best way of pulling that pilot bearing out?
