- Jun 1, 2001
- Age
- 63
- 1987... sorta
Arrrggghhhhhhh!
Went to get in my tuck to run a few errands and smelled gasoline... not an abnormal thing with my truck.
but afterdropping my keys I see a wet spot... that's not right....
After poking and probing, and unbolting the T-case skid plate
I find that my tank selector valve is leaking... Not good
I know the valve is made of solid unobtanium
(this is why I have spares) but one of the spares
is untested another is known bad, the third is another problem
Ford changed the type of connector on the valve on the 1988's
Now understand that the valve is a riveted together unit that
isn't intended to be "worked on", I regarded that as a challenge
so mine is held together with stainless steel screws.
I've been "inside" this valve before as it's a "frankenstein" valve
(built from several others) so I get out my screwdriver and take it apart.
the problem? a tiny O-ring.
3/16" in diameter, with a 3/32ID, it's the valve stem shaft seal
(there are two push-pull valves inside the unit)
the O-ring is split... fortunatly after all that I have another O-ring
Problem solved? Not quite...
Now we start discussing collateral dammage, the gasoline leaking from the lead screw motor housing (that's how they operate the valves) dribbled onto the electrical connector and the plastic they used turned into a crumbly putty like substance.
So after correcting the mechanical problem (literally a $0.03 O-ring)
I get to deal with an apparrently insoluble (pun intended) problem
dealing with reconnecting five dangling wires to my fuel selector
valve because the connector shell fell apart...
If my truck was an '88 instead of an '87 this wouldn't be a problem.
the '88 valve uses the same connector body as the common TFI module
But from bench testing the '88 valve I have appears to be dead....
AD
AD
