"Hot-Wiring" a Ranger??
JoeCanada
Edmonton, AB
OK, so I'm going to look at this '88 Ranger, however, the guy says he lost the key for it. And considering it's been sitting in his yard for over a year, I'd kinda like to know if it even starts and runs before I try towing it away. So my question is, how would I fire it up without the key? I'll still have to get around the wheel lock if I want to drive it, but that's assuming it even runs.
Take the VIN to the dealer and they should be able to cut you a key for it.
You're not gonna get that information on here. A bunch of Rangers wouldn't want to make it easier to get their trucks stolen.
an 88 is to old for a dealer to cut a key from the vin. the only way i know causes damage
Cut the red wire and the black wire, and connect them together.
Not really, I have no clue. That's just how the hot wired the mustang in a movie I saw. :icon_thumby:
If you can get the lock cylinder out, you could just use a screwdriver untill you can get a new lock cylider/key. Other wise you'd have pull the ignition switch and splice some wires.
Turns out it didn't matter anyway...ignition cylinder lock was busted, so all I had to do was turn it (no key) and away it went. Makes it easy to replace with a new one too.
