- Apr 18, 2008
- Age
- 88
- Austin
Huh.... after installing a *180 T-stat and doing the HWBP my engine runs better, pings less, makes more power, gets better gas mileage, and because it runs cooler will last longer - but hey, I guess Ford knows best, so maybe this weekend I'll undo the HWBP and reinstall the stock T-stat and go back to the pinging and sluggishness and what-not.
So you have a problem with your engine.. Most likely you have carboned up piston tops..
Your repair has been to put MORE fuel into the chamber to lessen the "ping"..
You may think of it as running a 180* and a hot water bypass.. But the reaction to these methods is more fuel into the chamber.
Nope! You cannot get better economy by running richer! You are dreaming.
Before making such a modification one should research just what the reaction to that mod will be.
Running COLDER will add to the amount of carbon on your pistons.. Making the "ping" louder and more frequent. All modern motor oils are formulated to lubricate 210* engines. All motor parts are engineered and built to run at
210*.
In effect you have actually caused more of the original problem, and gave yourself worse milage.
Stupid ford engineers don't know anything! How could they design such a poor quality engine.
Big Jim
