k3eaxk3eax
- Oct 22, 2010
Here's one for you to mull over: Using a non-contact thermometer I discovered that the passenger side roter is running 20F. hotter than the driver's side. Also, the outboard pad on the passenger side was somewhat more worn. All this suggested that the slides and pins on the passenger side needed attention or the caliper's piston was not retracting, or yet still the flexible hose to caliper had deteriorated internally and was preventing an adequate return flow back to the master cylinder. I greased and cleaned the guides/pins, replaced the caliper and hose and the temperature differential remained.
I've yet to place a dial indicator on the roter to test for warpage. However, since only the outside pad showed somewhat more wear, I doubt that the roter will show warpage.
I'd be interested to hear form others on this.
Al in Philadelphia
Al in Philadelphia
