Hot distrubitor cap
bf750
Ky
It is what it is
64838
64839
Ok.
Do you have a question you would like someone to answer? Or is there something you needed to say along with your unfocused pictures?
Ok.
Just wanted to know if anyone has seen this before.and adjust your bifocal.😎😎
Was this a new cap, old cap? Details help, can't just post random pics and expect a diagnosis...
Generally it's a sign that the coil was arcing between the distributor cap and rotor button because of a gap or excessive resistance. Could be crappy parts, wrong parts, cap not tightened properly, or old parts that got a ton of carbon on them.
My trifocals were adjusted fine. The first 2 pictures are bad. That last picture is much better. But when you have a question, people will understand it better if you actually state the question instead of just posting blurry pictures with no text. I agree with Dirtman concerning the cause.
In all my years...not sure I've ever seen a cap that bad. They typically quit running (at least running horribly) long before the center of the cap melts away.
That's a wall hanger for sure lol
20,000 volts can do some fun and interesting things when it doesn't go where it should...
20KV?
My guess is that coil was working overtime and going all out closer to 50KV to do that damage.
Lol stock coil and cap and button is one year old. Thanks for help.It had a random miss them I just shut off. It wouldn't start back, when I popped the hood it was on fire. Friends brought new cap and button and so far so good.
Theres a lot of misses here.
Label that cap with make, year, engine and post it on every vehicle website in the world.
That can't be at all common.
What engine was this on?
It's posted in the Bronco II forum, but it's engine related and on the rail of a pickup bed. You have a V8 in your signature, but it's a 6 cylinder cap.
