EMB1230
Why do people make such a fuss/brag about horsepower so much? Is it not true that torque is what really matters when it comes to engine power?
I also get a kick out of people who think that what the speedometer says (in mph) has some sort of bearing on how fast it is.
Cool, thanks for the explanation, I do also know with larger displacement comes not so much HP but lots more TQ. as is the case with the early Vulcan & Essex 3.8L. Both had 140 horses but the 3.8 had 55 more ft lbs of TorqueTorque gets you going gets you off the line, horsepower keeps you going. It is important to have a good balance of both in a race application (and correct gearing). Torque is more important if you are intending to pull something. That's why (at least around here) people always brag about how much torque the new Powerstroke, Duramax, and Cummins lineups have.
Basically, it really depends on the application as to which is more important. However, I agree...a lot more people just focus on horsepower. I also get a kick out of people who think that what the speedometer says (in mph) has some sort of bearing on how fast it is.
Horsepower pulls hills accelerates and carries loads.Torque is a mathematical formula devised on a dyno[horsepowerx5252 divided by the RPM]there is no device measuring the twist of the crank shaft to figure it.
the dyno measures torque....then a formula is applied to consider the rpm,calculating horsepower.
torque is a force measurement,horsepower is how much work can be done in a given time using that force.
