- Mar 12, 2009
- Automatic
i have just rebuild my 4.0 about a month ago. had the block and heads professionally done, bored .20 over on cylinders. std size for all bearings. everything except the crank and rods were replaced. inspected the crank and it was perfectly in spec as well as absolutely no sign of wear.
now the problem is the pump is not working very well(at least im guessing its the pump). when its cold it does fine and hits 60-62 psi. after a few miles it starts idling at 20 than jumps to 50 at 2000 rpm. but as soon as at gets fully warmed up it will idle between 8-10 psi and will only get to 35 psi at 2500 rpm. as well my new rockers/lifters/pushrods are making noise now as well
does anyone have any advise that might help me avoid pulling the engine to change the pump?
