Hopping feeling
_dj_
My 94 4.0 has a nasty shake at any speed over 45 mph? I've had the wheels rebalanced fixed a bad lower balljoint and it still does it.. Nothing else appears to be worn out.. Any suggestions
_dj_
Out of round tires? swap front to back. Maybe lost weight/s on driveshaft or u-joint going.
All the bushing are good but I did just order the complete energy kit for it since the trucks 20 years old. How do you inspect the universals? I've never owned a 4x4 before so Im kinda lost.. Going from vw to ford is a big change lol
_dj_
Thanks.. it looks like I'm gonna be looking at them tonight when I change the rear gear oil
_dj_
No problem. Look up the axle code in the door sticker. If you have limited slip, you need to add friction modifier to the gear lube. Just an FYI.
Yeah I got all the stuff from the stealer ship
_dj_
Thanks for the input it's very much appreciated
_dj_
