Homemade Floor Shifter
snakedoctor99
Peebles,Oh
Hey guys just got my 351w and c4 tranny all situated in my 83 ranger. still got one thing left to do though gotta hook up a shifter of some sort. my truck was originally a standard and was wondering if anyone on here ever built their own floor shifter for this swap. thanks
I would buy a hurst or some other aftermarket shifter but as everyone knows money can be a little tight these days so i figured that i would try to make one first for temporay use.
I would make a factory shifter work. It's not that hard to do and you can get whatever look out of it you want. I personally used a foxbody mustang shifter off an AOD. Its a cable shifter that fits pretty well... just have to run the cable in a round about way and fab up a mounting point..
It's one of those things where you can go many routes for success. I chose to save some $ and maintain a stock appearance.
I used a B&M Unimatic. It isn't really a performance shifter... just a floor shifter.
Looks nice and shifts nice though, I like it. :icon_thumby:
got it figured out made my own shifter using a old 5 spd shifter rod. then i welded a bracket to my shifter coming out of the tranny connected both with a steel rod. still gotta put in park and reverse lockouts but i can shift from inside the cab now
The floor shifter assembly from a Bronco II may bolt right into your 83, it did on my 89, then all you need is either a shifter rod if you have a floor shifter C-4 or a cable assembly if it's a column shifter C-4. Pull back the carpet and see if there's a floor plate bolted in that the 5 speed shifter hole is in.
