jeepxj2007
I am in the phase of building a trail ranger and I have a dd right now. My daily driver has a 3" bl and 34"s, the rear never rubs, the front will on hard bumps. This is how I got it from the p.o. So now on my trail ranger I want to build something that has a low center of gravity because there are a lot of steep angles and what not around here, and I am building this thing to be fairly cheap. I was originally going to go with a 6" lift and 2" body lift. I am still sticking with poly bushings and a 2" body lift. My question is I am looking at something from the 2-3" range of a suspension lift. I will not run anytires larger than 33" and the rear is going to be a homeade box with very high fenders so that isn't an issue for rubbing. I have a belltech shackle in the rear, which I will combine with either add a leaf and the ranger pack or explorer pack...about how much lift could you estimate for each. Now is there something I can do to make the front match? In the 2-3 inch range...this is going to be a light use dd and mainly a beater truck in the woods. I want to replace the coils so I am sticking away from spacers. Is there a jeep coil that can get the lift I want and still flex nicer? Do I have to get new brackets because I really dont want to but dont want it to go everywhere on the road. Any advice?
