home made tools
Destroyer000
January 2009 STOTM Winner
MTOTM Winner
Solid Axle Swap
Plattsburgh, NY
1999
just seeing what every ones brewed up with their fab skills..
post some pics of what you have.
The only one I have right now is a screwdriver I welded to the tool for my angle grinder. Kept grinding my fingers cuz the tool was too short. I guess I also did make a D44 upper ball joint insert tool out of a socket too.
My buddy has a bunch of sockets welded on the open end of wrenches. Kinda nice for torque converter bolts.
Another guy built a tubing bender out of a snowplow pump...it is really bad ass. I wish I knew him better so I could take some pics. He has a small machine shop and a good majority of the tools he has are stuff he built from scratch.
I got only one so far. I work on bicycles as a second job and I don't have the tool to set the star nuts in the fork so I pressed a socket onto teh end of a screwdriver. Hold the screwdriver handle, rest the socket on the star nut and tap them in with a mallet. Works like a charm.
i got alot of wrenches that i heated up and bent at a 45 degree angle. o yea and i got a couple philips screwdrivers that were beat so i ground them down to flat heads. lol im sure you guys have a couple of those...haha
I still have even after 20 years a little chunk of steel i made into a clutch centering tool. The night i was doing the clutch the kit i had rented for the centering tool. For some reason that i have no idea why didn't have the correct size for my mustang.
LUCKY for me i was in a friends shop and he had a small lathe. 10 minutes later and 3 inches of bar stock later i had a centering tool for a 302 =>
