- Sep 23, 2007
- Age
- 97
- Automatic
And a "poor man's purge" is to charge the system with R134 let it sit for a while (a couple hours) then unscrew the shrader valve under the high pressure cutoff switch and bleed the R134 to the atmosphere
So basically you keep charging and then releasing until all the air is out? That sounds rather wasteful, but I suppose it could work if you got a lot of 134 on hand.
How effective is that, say compared to a vacuumed down system?
134a is heavier than air so in a filled and "settled" system opening the system at the highest point will force the air out the top.
Alot of systems now days, often the shraders are not near the top of the system.
Can you possibly "flush" the R134a system of air? By simply open the high side and pull refrigerant into the low side for a few minutes?
