- Oct 14, 2018
- Sierra Vista, AZ
- Manual
1995 Ranger 2.3 manual trans.
At idle vacuum is sitting at 25 +/- a bit. When I step on the gas, moving or stationary, vacuum drops to between 8 and 10. I've seen low vacuum at idle, typically from some sort of leak. I have never seen high vacuum at idle and low under power.
I guess am asking what is the normal vacuum range? I was told by a buddy that the ranger should be sitting at about 18, drop a little but not 17.
Has anyone seen an issue like this? If so, can you point me down the right path? I have searched the forums but haven't found anything that fits.
Thanks guys.
Thanks guys.
