High Rider part numbers
AZ86B2
Tucson, AZ
Does anybody know the part numbers for the 87-89 Ranger "high rider" axle pivot and radius arm brackets? I would really rather bring a part number to the local stealership than watch them try to find them for 40 minutes on a system that seems intentionally designed to be impossible to use.
Good luck with that. They normally don't stock parts that are over 10 years old. The STX highrider brackets haven't been made for 20 some odd years now. They are getting really hard to find new. you may luck out and find a dealership that has a set in stock, but the odds are likely 1 million to one.
need better than good luck, they have been sold out for years and no longer make them.But if you want to give it a try here is the axle/beam piviot numbers.
E77A 3KO9O-BA
E77A 3BI78-AB
I have a pair that are rust free for sale.Pm me if you like.
pm sent. they are part of an idea that I have for a bastard lift. I already have the springs I need... the only other thing would be extendend rad. arms (pref SJ) and pitman.
