HondaEater
- Sep 30, 2010
What is the flow pattern of the cooling system for a 2.8?
The lower rad hose of my truck isnt getting hot all of a sudden,
im trying to figure out weather there is blockage in the system, the
thermostat is getting stuck, or worse, possibly a headgasket.
The oil pressure gauge is reading high too, that's why i fear the headgasket(s)
may be slipping.
Going to do a compression test tomorrow, and pull the thermostat to see if i can solve the problem, just trying to get this thing fixed, it's my daily driver. Thanks
Also, i have the thermostat on the upper hose, not the lower. The upper hose is warm as well as the bypass, but the lower hose is not
may be slipping.
