9's
- Nov 24, 2008
1st off , new here and so much great info...lovin it.
I searched and read thread after thread. I have an idea of where to go with this but have also read stories of guys spending hundreds replacing sensors one at a time with no fix.
94 4.0L 5spd 2WD 89k.
Just bought truck(yes with the prob
hehe)
PROBLEM IS: The RPM's dont drop between shifts. They stay around 2200. Also seems to be tied into the truck moving. For example: if coming up to a light I can put it in nuetral and the truck will idle at about 2200....UNTILL stopped>...then it kicks down to about 1200(still high, yes I know)
The truck runs fine under load. No power loss, no hesitation, no sputtering. Pulls at a linear rate through all gears.
I have noticed that if let sit at idle for a few minutes the idle WILL kick down from 1200 to closer to spec- about 800rpm....but this problem occurs when Im moving and is pretty f'ning annoying
-I've pulled the IAC...cleaned it. Took the two pieces apart(motor and valve). ALso did the quick check of disconnecting it while idleing...yes the idle changed. pretty much died.
-Cleaned the MAF with QD elc.cleaner
-Took off the TPS and tried to clean but there not much ya can.
-Checked air filter-its new
I'm going to pull codes from it tonight but there is no CEL. looking for a possible stored code
To me it sounds like it has to do with the TPS- since this 2200 idle happens only while truck is rolling....soon as those tires stop....idle kicks down.
What other advice do you pro's have for a newb like me. I've tried to get it with just past threads...but mostly they are stationary idle problems, so I made my own
