Ranger4x4newb
- Jun 27, 2015
- Automatic
So watching my live data on my code reader my calculated engine load is between 34 and 37 percent at idle and 47 while I'm cruising down the road at about 35 and going uphill it pushes close to 73 and that's without the AC running too. I'm having trouble with my battery staying charged and my alternator almost kills the car when I load test it. I've tried all the usual stuff,new o2 sensors, throttle position sensor, maf sensor, cleaned the. IAC and throttle body. I've also tried mopar combustion chamber cleaner, gumoit multisystem tune up (the kind in the seafoam like can), seafoam, Lucas oil and afterwards I changed the plugs wires and coil with motorcraft plugs and an accel coil and there is still no change at all.
Does any else have any siggestions to try?
Vehicle is a 98 4.0 OHV 4x4 auto
