High capacity fuel tank
I'm not aware of any that bolt into the stock location, but I'm sure you could have something custom made. If you don't mind moving your spare tire, removing the assembly and adding/modifying some cross members then a 23 gallon BII tank could be mounted behind the axle.
Probably a much better option for a 98+ truck would just be an auxiliary fuel cell mounted in the bed.
