HID retrofit wiring? HELP
scottsdale
I just finished retrofitting a set of h1 mini projectors into the stock housings of my 01 mazda. I cant figure out the wiring. The truck harness has a HB5 connector but the kit is H1 bulbs with a shutter in the projector. I am a noob at wiring and I cant figure out how I should wire everything up to get it working. here is the same set up I have
http://www.rangerpowersports.com/forum/f53/my-mazda-projector-mod-278106.html
there is a poisitive and a negative wire for the bulb and a positive and a negative for the projector. the harness has a ground, a high beam and a low beam power wire for a total of three wires. Any suggestions?
