RGMs03
- Apr 14, 2009
I need HID Help
so i decided to order one of these cheaper hid kits that only give you the opion of having your low beam unless you want to spend that extra $. i decided try the basic single beam kit as i dont use my high beams at all. i got the kit from 70dollarhids which offers a lifetime warranty.
the kit seemed pretty easy to install just hook up the corresponding wires plug it in to the existing harness for the regular headlights and thats it. it didnt even come with instructions its that easy, or did they just forget to package them. anyway its all hooked up and the lights wont turn on. i double checked everything and it all looks good. i called the guy and asked about the install he said it may neeed a bigger headlamp fuse,i tried that (didnt work) he said it may need a relay harness they are 35 bucks on his site i'm about to go look at some auto stors to see if i can find 1 that will work. has anyone used this type of kit or something similar? Any help is much appreciated.
