Gary DuBois
- Jan 30, 2017
- Age
- 34
- Puyallup Washington
- 4.0 V6
- Automatic
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- 31 inch
Got any pics of that 68? I dont think ive seen itGary, I know you mean well, but I''d caution against sharing something like your CarFax or Marti on public forums. Most likely you'd be ok, but there is the potential for bad actors to use that information against you.
In this case your link does not work it takes people following it to a sign-up page for CarFax, not to your report, but anyone that can see the link can see your full VIN number.
If you want to share a report like this or your Marti report I would suggest taking screenshots of the report, removing and personally identifyable informamtion, and then posting the modified screenshot.
As an example I'll post the MARTI from my 68 F-100. I took a screenshot of the sheet and edited it in paint. The only critical information here was the serial number and I blocked it out. If it had contained any of my personal information like name, address, and phone number or a license plate number as may have been found on a CarFax report, I'd have blocked out those as well.
I like it...alot.Only good picture I can find at the moment. Chassis is 1968, dad put the 70 body on it back in the 80s when the original practically fell off from rust.
At current it's mostly a rust bucket. Slowly getting some small odd and end projects done on it. Have installed a Holley Sniper on the 360, still needs proper tuning. Upgraded to front disc brakes, still trying to get those ironed out. Just replaced sticking calipers a couple weeks ago but not working well, need assistance to properly pressure bleed. Did a power window conversion last month, which will hopefully make it more comfortable to drive for more of the year until I can add AC.
Have a few more solid panels to install like a hood bed and inner fenders. Cab, fenders, and frame are pretty solid. Next few years is mostly maintaining and trying to make a decision on future drivetrain. Rebuild FE and upgrade transmission or modern drivetrain swap, kind of leaning towards modern swap for reliability, usability, and ease of maintenance (aka parts availability). Hope to have a shop built by then and really be able to get into a "restoration". Dont care about show car, but want it to look good and last another 55 years.
I plan on starting a full size truck build to pull a camper in a year or so. Plan on using the 302. What do you think of the Sniper System? I did not like it when fuel injection came in on 85-86 time frame. Now I really like fuel injection/throttle body over carburetor. When I get to my full size build, Holley Sniper is on the list to look at.
