- Jan 29, 2010
- Central Indiana
I know mine has an issue with the TPS, and as I said earlier it drives totally fine most of the time. The only issues I ever see, are an occasional hard-to-start, caused by over fueling on shut down. Mine seems to do it more while hot than cold, which sounds a bit different from your issue, but don't dismiss a fluky TPS just because the truck drives normally most of the time.
Also, if you're going to replace the plugs, don't waste your money buying fancy platinum ones. Most 3.0 owners have far fewer issues with boring, cheap, copper Autolite 103s or the Motorcraft equivalent. It's what the owner's manual calls for. Just make sure they're gapped properly. Adding fancy plugs will just make one more potential contributor to your running problems.
