Help!
i blew the tranny out of my 00 ranger. it had a 5 speed behind a 3.0. put the used tranny in with the slave cylinder that came in it. put a new line from master cylinder to slave cylinder and it wont build pressure. could it be a cracked slave? im going to use a pressure bleeder on it tomorrow. thanks for the help
I bet your on track with the power bleeder, there hard to bleed.Ive had good luck back bleeding through the bleeder screw and one of those syringes for injecting meat with a vacuum line on the end.
