yes,it is possible, a 3.0 will probally be harder than anyother motor because it will require you to put in a new tranny as well. If you want more power put in a 5.0 IMO
yep, tis true that the 3.0l is the lonely bastard of the bunch. if you want to swap in a 3.0l, then you are going to need a wiring harness from the donor truck and alot of time to invest in swapping it.
For
