beaujt
I swapped an explorer 8.8 w/ disc brakes in my ranger. now the brake pedal goes to the floor with virtually no pressure when the engine is running. but when its off, the pedal has a lot of pressure. I think i've gotta put a new master cylinder in to compensate for the disc brakes in the rear, is that right? or is there something else i should check? I've got the rear up in the air and i can't even get it to come to a stop(the rear). If i need to replace the master cyldiner can i get away with using one from an f150 or do i need to get an explorer one?
