help
sclove
Sc
hello my rangers friends i have a 1988 ford ranger .with a 2.9 v6 it runs for about 5 mins then it acts like its stravin 4 fuel i have replace both fuels,i have replace o2 senser i have replace both fuel filters whats next ? when i drive it it runs good 4 about 5 miles then it cuts off n wont start u got to keep turnin 4 a while until it starts
When a vehicle won't start, puting an once or two of fuel down it's throat will tell you if you have a lectric problem or a gasoline problem.
Many lectric problems will lead guys to THINK they have a fuel problem.. Make sure what you are working on before throwing parts at a problem.
Big JIm
test your TFI (aka ignition module) from what you discribed is classic heat issue.
local parts store can test them...ususally free.
located on the back side of the distributor.
