Help with U bolts
dangerranger2008
Ky
i have a 2002 ford ranger 8.8 rear with 4.10 and i am doing a swap for a 1997 ford explorer rear end so i can have disc brakes. the rear end from explorer rear end is 8.8 with 4.10 i need u bolts for the does any one know a part number or how long and wide they need to be.
Axle diameter (3.25") + spring pad height above axle tube + factory 4x4 lift block thickness + spring thickness + spring retaining plate + an inch or two extra = required bolt length.
Best I can do without my truck to look at. :icon_thumby:
