Cchapa020
Hello I’m having a loss of power when driving I’ll drive around fine then very so often the truck will lose power it seems to go away mostly after I get it to 3000 rpm or so but when this occurs and I press the gas either the engine won’t take the gas or it screams like I should be doing 120. I’ve checked for vacuum leaks none whatsoever. The truck starts every time no issues idles fine until it loses power then when I come to a stop light the rpm needle starts hunting for a comfortable spot and sounds like I’ve got a massive cam on it. I really like this truck I just can’t figure out what it’s issue is
