davemayn13
- Dec 12, 2008
- Automatic
Hi guys! First time here on the forums, I've done a lot of looking but no posting. Now I've got an issue and maybe somebody can help me out.
I've got a 1992 Ranger with a 2.3 and a manual tranny. Here's the problem. My check engine light is on. On the non running test it keeps throwing a 118 code, which according to the codes is an ECT high or open. My temp gauge is unresponsive and does not move as it warms up. I replaced the thermostat and the ECT sensor. It kept throwing the code on me. I pinched the upper hose when started and it wasn't pumping coolant cold, but did open up as it warmed up. I grounded the temp sender wire and found the gauge went all the way to hot. I'm now assuming that the temp sender is bad, but would that cause it to throw an ECT code? Anybody else had this problem?
Dave
Dave
