Crashtest84
This may need to be moved but I was wondering about how much torque the 2 piece shaft that you have to build for a doubler has to handle as kinda need to know how strong it needs to be built I read the two post in the tech and there wasn't much said about really how they made them other then it seems better to weld then to press that brings me to my next question on the old trans output shaft was it just cut off at the end of the splines and welded to the sector shaft or would it be better to turn down the output shaft so that is would fit inside the sector shaft and then weld it by the splines and at the front of the sector shaft to ? I guess what im just trying to ask here is what would be the best way to make the shaft ?
